Toggle introduction video! http://www.thing-printer.com/toggle-1-0/
Thanks would love to see more on these kind of “intro” video.
Can you set the heater temps through toggle?
@Tim_Curtis the preheat values are taken from the settings file.
Ok thanks. So you can’t manually enter heat values?
No, unfortunately not.
I’d like to update but i’m not programmer. Will I find some tutorial about installing packages on BBB?
Thanks for the video Elias!
So toggle is working fine with the octoprint plugin and for jog, pre-heat of the bed and hot-end, but the loading of models on the display does not. It just sits there “thinking”. I have only three STL files in there and a bunch of gcode files. Is it getting confused trying to display the gcode files? As I understand, toggle displays STL files only. Could this be the issue?
@Daniel_Kusz from memory you should be able to update by calling “apt-get install toggle” from the command line. This assumes your BBB is connected to the Internet.
@Daryl_Bond should I use puTTy to do this?
Yep. Connect through to the BBB as user root and you should then be able to use the command line interface to do everything you need.
How do i invert the gecode picture on manga screen? Becouse on my screen it’s mirroed.
@Daryl_Bond Thanks! I have the last question. Package will download automatically?
If you log into the BBB as root with puTTy then call ‘apt-get update’ then ‘apt-get install toggle’. That will first update the list of available software packages and then install the toggle package. You may also want to install the octoprint plugin for toggle ‘apt-get install python-octoprint-toggle’. You may need to look up the name for the plugin as I am going from memory here!
@Jan_M_Simonsen , I have not not found a good way to solve this yet unfortunately, It is a bug listed in issues! Sorry about that!
