// Glediator to WS2812 pixel converter #
// by R. Heller #
// V 1.0 - 07.01.2014 #
// http://wwww.SolderLab.de #
// Receives serial data in Glediator protocol format @ 1 MBit/s #
// and distributes it to a connectect chain of WS2812 pixels #
// Adjust the correct DATA PIN and the correct NUMBER OF PIXELS you are using #
// in the definitions section below before uploading this sketch to your #
// Arduino device. #
// Maxiumim number of supported pixeles is 512 !!! #
// In the Glediator software set output mode to “Glediator_Protocol”, #
// color order to “GRB” and baud rate to “1000000” #
// Definitions → Make changes ONLY HERE #
// To find out the correct port, ddr and pin name when you just know the #
// Arduino’s digital pin number just google for “Arduino pin mapping”. #
// In the present example digital Pin 6 is used which corresponds to “PORTD”, #
// “DDRD” and “6”, respectively. #
#define DATA_PORT PORTD
#define DATA_DDR DDRD
#define DATA_PIN 8
#define NUMBER_OF_PIXELS 40
// Variables #
unsigned char display_buffer[NUMBER_OF_PIXELS * 3];
static unsigned char *ptr;
static unsigned int pos = 0;
volatile unsigned char go = 0;
// Setup #
void setup()
// Set data pin as output
DATA_DDR |= (1 << DATA_PIN);
// Initialize UART
UCSR0A |= (1<<U2X0);
UCSR0B |= (1<<RXEN0) | (1<<TXEN0) | (1<<RXCIE0);
UCSR0C |= (1<<UCSZ01) | (1<<UCSZ00) ;
UBRR0H = 0;
UBRR0L = 1; //Baud Rate 1 MBit (at F_CPU = 16MHz)
ptr=display_buffer;
//Enable global interrupts
sei();
// Main loop #
void loop()
if (go==1)
cli();
ws2812_sendarray(display_buffer, NUMBER_OF_PIXELS * 3);
sei();
go=0;
// UART-Interrupt-Prozedur (called every time one byte is compeltely received) #
ISR(USART_RX_vect)
unsigned char b;
b=UDR0;
if (b == 1) {pos=0; ptr=display_buffer; return;}
if (pos == (NUMBER_OF_PIXELS*3)) {} else {ptr=b; ptr++; pos++;}
if (pos == ((NUMBER_OF_PIXELS3)1)) {go=1;}
// WS2812 output routine #
// Extracted from a ligh weight WS2812 lib by Tim (cpldcpu@gmail.com) #
// Found on http://wwww.microcontroller.net #
// Requires F_CPU = 16MHz #
void ws2812_sendarray(uint8_t *data,uint16_t datlen)
uint8_t curbyte,ctr,masklo;
uint8_t maskhi = _BV(DATA_PIN);
masklo =~ maskhi & DATA_PORT;
maskhi |= DATA_PORT;
while (datlen-)
curbyte = *data++;
asm volatile
" ldi %0,8 \n\t" // 0
"loop%=:out %2, %3 \n\t" // 1
"lsl %1 \n\t" // 2
"dec %0 \n\t" // 3
" rjmp .+0 \n\t" // 5
" brcs .+2 \n\t" // 6l / 7h
" out %2,%4 \n\t" // 7l / -
" rjmp .+0 \n\t" // 9
" nop \n\t" // 10
" out %2,%4 \n\t" // 11
" breq end%= \n\t" // 12 nt. 13 taken
" rjmp .+0 \n\t" // 14
" rjmp .+0 \n\t" // 16
" rjmp .+0 \n\t" // 18
" rjmp loop%= \n\t" // 20
"end%=: \n\t"
: "=&d" (ctr)
: "r" (curbyte), "I" (_SFR_IO_ADDR(DATA_PORT)), "r" (maskhi), "r" (masklo)
// End of program #
