Hi all,
'Spent quite a long time hunting for info on how to setup touchprobe for a CNC setup.
Should work with G30: moving the bit toward the object to carve…
Sound much simpler than all levelling strategies !… but can’t find any reference.
I’m using 3 endstops already (X min, Y min and Z max)…
- where should I hook Z touch (and how to I get to monitor state ?)… using switch table ??
- can use a stripped out mechanical switch (closing when bit enter in contact with target surface) or will it fry my board ?
best,
e
the anwser was so simple :
- pick a pin available (my 1.25 was free on my CNC)
- 2 wires:
- one from “GRD” to the spindle (turned off, don’t be a pain)
- the other from “SIGNAL” to a metal plate (or the part to machine if made of conductive metal)
- edit config to enable Z-Probe and assign proper pin
G30: tadaaaaa. there you have it ! auto sensing*
and then all the pleasure of G30.2 G30.3… scanning touch probing in X or Y your stock: awsome.
'should be in the wiki in CNC mill section.
e
- providing you correctly initiated, homed, set zero, etc., etc….
