Has anyone gotten the Bltouch working with Replicape? They released another version since last time I asked, so maybe more people have them? I have yet to buy one; waiting to see for sure they work. The config is what I’d be curious about.
Question, if this is the “new” BLTouch, from what I see is referred to as BLTouch-C or “Classic”, then is it really a new model or just a new name? Classic infers an old or previous model.
I know very little about the development of these sensors, I know that this white/clear version replaced the yellow version of old, but what was upgraded/fixed/replaced I do not know.
I just know I have a glass bed and my inductive sensor over aluminum tape is not the best solution for me, as I’ve discovered with bed probing malfunctions and adjusting distances while calibrating my steps_per_mm.
Having a physical button without a swing out arm, the BLtouch essentially, sounds like a great solution to me.
If you are certain you saw somewhere a Bltouch working with replicape, then that is pretty much what I Wanted to know, that it works. Getting spoon fed a config would be even nicer, but can’t have everything
Thanks for tracking down my inductive sensor issue last night causing homing issues with g29 so that I can get by for now; it working at least re-energized my enthusiasm for the project.
This Bltouch sensor would be the next fix to eliminate jamming my print head into the bed when it isn’t over my preset aluminum tape points.
I would love this sensor to work Elias; I don’t know of anything that works better. Because of issues with inductive sensors and glass beds, I can’t recommend that route. If swinging arm + micro switch was Level 1, the BLtouch with no physical arm swing with a mechanical button is Level 2.
No i did not get it working, there is some strange problem with detecting pulse-alike end stop events. Did file a issue on bitbucket, as i believe it is some how related to PRU code.
Or to be more precise redeem / replicape will detect those pulse-alike signals, but for some reason it does not break actions on PRU0. Othervise BLTouch is working right as it supposed, all “servo commands” are working etc.
@Ville_Jussila@Philip_Acierto OK, thanks for clearing that up. 10ms might not be enough to test for end stop hit + delete all remaining steps in the buffer/path. Most likely this will need some manual mingling, ideally in the form of a plugin that can capture the event and set the end stop until it returns etc. I’ve been looking at something similar to this, since I am currently researching different probe mechanisms, for my upcoming video documenting the bed probing and a friend has a somewhat special solution using an accelerometer. If I get that working, a solution for BLtouch should not be too far away.
Is the short pulse (10 ms) from BLtouch now handled correctly by current software relase?
I am asking as I plan on adding the BLtouch for auto levelling to my Podrap1 XXL cartesian dual extruder printer:
