Tried the Torture test print on my Printxel. I have issues
Issues with flow and Y skipping. My Ymotor did reach 82*c
during the print.
It looks like your Y axis is binding. Is this the axis that you swapped out the driver?
Hi Billy
Yes. I did adjust the driver but haven’t tested it yet.
Most likely a driver adjustment problem.
Turn the pot on the driver down all the way and then turn it up 90 degrees. Work on from there.
I plan on that @Mano_Biletsky_Open_M plus see what’s up with the Y axis belt/rods. To check for binding. Might have to take it apart again.
I tweaked the pot and took apart the Y axis and this is a comparison shoot. Todays in the back. Y motor stayed at 47*c.
http://flic.kr/p/eZcWaA
Nice! Good to see it helped!
Looks like your layers are quite nice and it seems the only thing preventing a nice print are the drop outs. Do you have the new style tensioner with the bearing?
Yes @Billy there is a bearing in the middle.
Here is a video that I threw together that demonstrates the
noise associated with the Y axis problems before and how it sounds now.
