Hi,
As the title says, I am trying to duplicate the mechanism to read parameters form the config file of the SmoothieBoard.
The reason for that is I need two configuration files for the smoothie-project that I am working on.
I just have on problem, I can’t find where _binary_config_default_start and _binary_config_default_end from FirmConfigSource.cpp are defined.
Here is the code in question :
// we use objdump in the Makefile to import your config.default file into the compiled code
// Since the two symbols below are derived from the filename, we need to change them if the filename changes
extern char _binary_config_default_start;
extern char _binary_config_default_end;
It says that they use objdump in a Makefile but I checked all of the Makefiles and can’t find it!
Thanks in advance,
Nicolas Gagnon
