Trying to figure out how to convert a NeoPixel code to FastLED. This line is killing me.
strip.setPixelColor(length-i-1, half_array[i]);
What would be the equivalent in FastLED?
Can post the whole code if it’d help.
leds [length-i-1] = half_array[i];
FastLED.show();
In general, where the Adafruit code uses
strip.setPixelColor( position, color);
the FastLED equivalent is
leds[ position ] = color;
There are all sorts of other details that are different, but where they use a function call to setPixelColor, we let you directly set values in the led array.
I keep having half a mind to add
FastLED.setPixelColor( pos, color);
as an API call, but so far there are still a pretty good number of reasons why we don’t do it that way. As it is, it’s pretty easy to convert the code to the new direct-access way.
Speaking as someone who is undertaking the exact same conversion task, I favor the direct -access method. The code is cleaner. Position is the array index and color is the value.
