Trying to get slow and smooth transitions at the low end of the brightness
Trying to get slow and smooth transitions at the low end of the brightness range. 8 bit color resolution really sucks. Avoiding any RGB part to go lower than 1 limits the pain but the price is a lack of contrast.
Since we have some really fast LED chipsets - has anyone ever written a temporal dithering in order to get some extra bits for the color resolution?
Example: 10 bits would mean 2 extra bits. The possible brightness range of one 8 bit color (0-255) would be extended to 0-1023. Which would mean that we have 3 extra steps between 0 and 1 (of 255). The price would be to get only one quarter of the framrate. For setups that run in the kfps range that should be no problem.
One step further: What about a 10 bit temporal dithering that runs in the background in order to achive a decent gamma correction while we could keep the 8 bit math?
How hard would it be to utilize FastLEDs existing temporal dithering at full brightness in order to soften the brightness steps at the lower end?
Any thoughts?
Making use of the existing temporal dithering with 16-bit CRGB objects is part of the plan for the rgbw/rgb16 work when I get back to working on the library.
I did this one once: https://gist.github.com/kasperkamperman/4461a70dd0841f80ddf4
If you use the APA102 chips you can use the GBC. See: https://github.com/embedded-creations/apa102-gbctest/blob/master/apa102-gbctest.ino
That example isn’t documented well and the code isn’t efficient. There’s more in this long thread: https://community.particle.io/t/smartmatrix-apa102-library-open-hardware-photon-apa102-shield/21562
Great, thanks for the input everyone!
