Turn on laser
Haven’t used Laserweb in combination with the Elekslaser for years. And somehow my settings are gone…
When I hit [Laser Test], then it fires. But the laser does not turn on when I try to cut a shape. It drives me nuts…
Any hints what I missed?
My Settings:
$32=1
Gcode Start (default):
G21 ; Set units to mm
G90 ; Absolute positioning
M4 S0 ; Enable Laser/Spindle (0 power)
I would make sure that the marking input on the LPS is working also.
If this is a k40 style LPS the L signal (rightmost connector) is the port for modulating the laser.
I would disconnect that port wire and gnd it temporarily. Make sure that laser is enabled.
@donkjr The Eleksmaker is a Diode Laser, so no LPS there.
@enhydra If the [Laser Test] button works, then at least your firmware settings are ok. Did you start with the [Generic GRBL machine] profile in LaserWeb? (hit apply after selecting the dropdown)
You should also check the Gcode settings in LaserWeb:
[GCODE GENERATOR] should be default
[LASER INTENSITY] should be S
[PWM MIN S VALUE] should be 0
[PWM MAX S VALUE] should be 1000 (grbl default)
Thanks for your reply. :slight_smile:
Problem solved! The laser worked perfect. It was the CAM part, which caused the problems. With the comment from @Jorge_Robles I was able to solve the issue: Check Size doesnt turn on laser · Issue #457 · LaserWeb/LaserWeb4 · GitHub
