Hello,
I want to upgrade from Melzi Ardentissimo to Smoothieboard. However, on my Prusa i3 printer, I have two motors powering the Z axis, and these motors are powered from a single output on the Melzi. Can Smoothieboard handle two motors like that? Or do I need to get more expensive 5X version?
PS: I bought this printer as a kit on Aliexpress two years ago, so therefore I have no access to firmware configuration.
My DIY printer with 2 motors on the Z axis is using the 5X Smoothie. I have two extruders. So I bought a $20 stepper driver that had enough amperage capacity to run both of my motors. I set the amperage at 2 times 1.68 amps ( my motor max amps) and hooked it up to the pins for the No 3 onboard stepper. Works great.
Thanks for fast answer :).
Could you tell me, how did you do it in more detail? I understand, that I need to buy something like this[1]. However, how I’m supposed to wire it? To which pins should I solder wires? And also the table printed on top of the stepper driver PCB scares me. I know very little about stepper motors, so I’m sorry for noob question.
PS: replace this “:” to this “.” to make the link working. Forum software doesn’t allow me to post links…
This is what I used…
MYSWEETY TB6600 4A 9-42V Stepper Motor Driver CNC Controller, Stepper Motor Driver Nema tb6600 Single Axes Hybrid Stepper Motor For CNC
For instructions try the documentation for external drivers.
Do you use the common anode or common cathode? I have the same driver and can’t get it running. When I try to move Z-axis you can hear the stepper tries to move but nothing happens
