After I issue a G28XY command the printer eventually halts.
Example: I’ll move the extruder to the far adjacent corner from the homing corner. Then perform a G28 XY. Before it is able reach home the machine stops and returns
Read: Error: Homing cycle failed
Read: ok
I can then clear it with M999 and home again, which works. But if I’m far away it never makes it. If anything it stops soon after X hits its respective alpha_min endstop but never makes it to the beta_max endstop (home to max on beta)
It is a cartesian machine
flashed with current edge firmware
controlled through Simplify3d (same issue occurs in printrun as well)
Also I am using a BLTouch. When I run a G32 it does the same thing. Sometimes mid cycle but usually just becomes non-responsive after it has finished the routine.
Please see the paste bin link for my config file
Any help would be fantastic. I’ve spent a ton of time searching with no avail.
config file link located in summary ( sorry I did not understand how to post it correctly
