Update.
Calibrated with specs from M8 data sheet.
I calculated 304 steps that was needed.
Nozzle 0.4mm
Layer height 0.2mm
Extrusion width 0.48mm
2 shell Parameters
180Deg temp
PLA 1.75
Extrusion multiplier 1
The cube is a 20 x 20mm
0.48 per outer parameter X 2 parameters = 0.96 expected shell thickness.
I think I’m on the right road now.
Anything obvious you notice that needs further refinement, please post.
Thanks everyone for your advice and help.
Trhuster
(Trhuster)
2
Looks pretty good to me. You can try a 3dbenchy now and if it is good to just print away with some real prints.
You can probably drop the extrusion width to .35 to keep your extrusion width below the nozzle diameter. Other than that, looking good!
Trhuster
(Trhuster)
4
@Keith_Applegarth Eh, no. Why would you ever even try to do that. 0.48 is a good place to be with a 0.4 nozzle.
@Trhuster I stand corrected!
