Upgraded my Solidoodle 3 heated bed.
Upgraded my Solidoodle 3 heated bed. the original was warped so bad it was nearly useless
https://drive.google.com/file/d/13oWMydOkMsVWcKWHaPtRnz0YU1OWxbNV/view?usp=sharing
How thick is it? You should consider to put on at the bottom insulation i will heat fast and will loose less heat dissipation.
@Benjamin_Lukman I have an insulation blanket laying under it. I took it from the original bed, just haven’t glued it on yet. Need to find some high temp spray on glue is what i’m thinking. The plate is 1/4’ thick
@John_Foreman better is double side tape and it would be easy for you.
Please Subscribe This Channel And Like This Video And Share Your Friend.
Thank You…
@Benjamin_Lukman any particular type of double sided tape?
@John_Foreman something like this on AliExpress “Adhesive Tape Double Side Transfer Heat Thermal Conduct” we have company Tesa i use that for bouth my printers Creality cr-10s and ender-4 plate heats up faster and consuming less power.
