upon homing x with NC limit switch I want it to go toward X=0 but when I hit the home button it actually went the other way… How do tell it to home toward x = 0?
I see this option “invert_X1 = True” but this looks like just for toggling NC to NO
I dont remember exactly but change travel Sign (direction) X in Geometry.
The travel sign direction is already how I want it; right is positive and left is negative and I didn’t want to flip that
Why? I think there is no other way, this is homing travel direction. Another possibility is to change homing speed but this means searching max endstop.
I didn’t see " homing travel direction" option I might have missed that. Will check on that.
I could flip the travel direction but I don’t want to do x-10 to go right side…
I mean travel_X is homing travel direction in Geometry section. When you change this you don’t need to put “-” to travel in the right direction in normal moves. This is only direction for homing I think. Check this.
[solved] thanks. changing +/- on travel_x did it
loving the silence at 10mm/s speed basically 0 noise…
