usb not recognized error code 43
Hello
I get a usb not recognized error code 43 when connecting my smoothieboard to WIN7 64.
I have tested the board on a seccond win7 machine and on a winxp labtop, and get the same error on them.
I have :
  1. installed the recomended windowsdriver
  2. installed MSD disable firmware and added msd_disable true # disable msd to setup file
  3. connected Reprap Discount GLCD, and it works
I could really use some help here
Would you happen to have access to a linux machine you could test on ?
Where exactly do you see a code 43 ? Did you try connecting via pronterface anyway ?
Hi arthurwolf, thank you for your reply.
No I do not have a Linux machine, I could download a bootable distro and burn that on a dvd.
I see the error code in windows device manager/properties.
I did try to insert a link to a picture, but are not alowed to do that.
Could you try just ignoring the error, and trying to connect with pronterface anyway ?
If you could boot up a linux CD and try on that, it’d help too.
Pronterface did not work, no ports to sellect.
Realized I had Ubuntu on an old labtop, nothing happen when I connect smoothiebord to it.
Shouldn’t it at least show the sd card as a drive?
What do lsusb and dmesg show when you plug the smoothieboard in, under ubuntu ?
Hi arthurwolf
For some reason I cannot copy all from dmesg listing.
This is what I get when smoothieboard is connected.
lsusb:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
dmesg:
[ 0.369787] fuse init (API version 7.17)
[ 0.369966] msgmni has been set to 1435
[ 0.380780] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.384348] io scheduler noop registered
[ 0.384355] io scheduler deadline registered
[ 0.384399] io scheduler cfq registered (default)
[ 0.384688] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.384732] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.385002] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input0
[ 0.404493] ACPI: Lid Switch [LID]
[ 0.404644] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input1
[ 0.404654] ACPI: Sleep Button [SLPB]
[ 0.404735] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.404740] ACPI: Power Button [PWRF]
[ 0.404889] ACPI: Fan [FAN0] (off)
[ 0.404948] ACPI: Fan [FAN1] (off)
[ 0.405017] Marking TSC unstable due to TSC halts in idle
[ 0.405029] ACPI: acpi_idle registered with cpuidle
[ 0.436273] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.436280] ACPI: Thermal Zone [THRM] (27 C)
[ 0.436392] ERST: Table is not found!
[ 0.436395] GHES: HEST is not enabled!
[ 0.436706] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.438968] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 10
[ 0.438979] serial 0000:00:1f.6: PCI INT B -> Link[LNKB] -> GSI 10 (level, low) -> IRQ 10
[ 0.439008] serial 0000:00:1f.6: PCI INT B disabled
[ 0.439268] Linux agpgart interface v0.103
[ 0.439354] agpgart-intel 0000:00:00.0: Intel 855GM Chipset
[ 0.439382] agpgart-intel 0000:00:00.0: detected gtt size: 131072K total, 131072K mappable
[ 0.439620] agpgart-intel 0000:00:00.0: detected 16384K stolen memory
[ 0.444383] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xe8000000
[ 0.445723] isapnp: Scanning for PnP cards…
[ 0.452633] brd: module loaded
[ 0.453943] loop: module loaded
[ 0.454242] ata_piix 0000:00:1f.1: version 2.13
[ 0.454264] ata_piix 0000:00:1f.1: power state changed by ACPI to D0
[ 0.454270] ata_piix 0000:00:1f.1: power state changed by ACPI to D0
[ 0.454278] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
[ 0.454293] ata_piix 0000:00:1f.1: PCI INT A -> Link[LNKC] -> GSI 6 (level, low) -> IRQ 6
[ 0.454354] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.547851] scsi0 : ata_piix
[ 0.548126] scsi1 : ata_piix
[ 0.549112] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1810 irq 14
[ 0.549118] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1818 irq 15
[ 0.549874] Fixed MDIO Bus: probed
[ 0.549909] tun: Universal TUN/TAP device driver, 1.6
[ 0.549912] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.550022] PPP generic driver version 2.4.2
[ 0.550382] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.550423] ehci_hcd 0000:00:1d.7: PCI INT D -> Link[LNKH] -> GSI 10 (level, low) -> IRQ 10
[ 0.550451] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 0.550456] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 0.550521] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 0.550563] ehci_hcd 0000:00:1d.7: debug port 1
[ 0.554460] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 0.560088] ehci_hcd 0000:00:1d.7: irq 10, io mem 0xe0100000
[ 0.572124] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.572458] hub 1-0:1.0: USB hub found
[ 0.572467] hub 1-0:1.0: 6 ports detected
[ 0.572613] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.572645] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.572710] uhci_hcd 0000:00:1d.0: PCI INT A -> Link[LNKA] -> GSI 6 (level, low) -> IRQ 6
[ 0.572728] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.572733] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.572820] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.572859] uhci_hcd 0000:00:1d.0: irq 6, io base 0x00001820
[ 0.573087] hub 2-0:1.0: USB hub found
[ 0.573093] hub 2-0:1.0: 2 ports detected
[ 0.573198] uhci_hcd 0000:00:1d.1: PCI INT B -> Link[LNKD] -> GSI 6 (level, low) -> IRQ 6
[ 0.573210] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.573214] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.573290] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 0.573316] uhci_hcd 0000:00:1d.1: irq 6, io base 0x00001840
[ 0.573531] hub 3-0:1.0: USB hub found
[ 0.573537] hub 3-0:1.0: 2 ports detected
[ 0.573632] uhci_hcd 0000:00:1d.2: PCI INT C -> Link[LNKC] -> GSI 6 (level, low) -> IRQ 6
[ 0.573643] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.573648] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.573711] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 0.573736] uhci_hcd 0000:00:1d.2: irq 6, io base 0x00001860
[ 0.573955] hub 4-0:1.0: USB hub found
[ 0.573962] hub 4-0:1.0: 2 ports detected
[ 0.574139] usbcore: registered new interface driver libusual
[ 0.574213] i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:MOU2] at 0x60,0x64 irq 1,12
[ 0.576100] i8042: Detected active multiplexing controller, rev 1.1
[ 0.580954] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.580967] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 0.580972] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 0.580976] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 0.580980] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 0.581186] mousedev: PS/2 mouse device common for all mice
[ 0.581592] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 0.581615] rtc0: alarms up to one month, y3k, 242 bytes nvram
[ 0.581777] device-mapper: uevent: version 1.0.3
[ 0.581914] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 0.581981] EISA: Probing bus 0 at eisa.0
[ 0.581992] Cannot allocate resource for EISA slot 1
[ 0.581997] Cannot allocate resource for EISA slot 2
[ 0.582000] Cannot allocate resource for EISA slot 3
[ 0.582025] EISA: Detected 0 cards.
[ 0.582044] cpufreq-nforce2: No nForce2 chipset.
[ 0.582125] cpuidle: using governor ladder
[ 0.582211] cpuidle: using governor menu
[ 0.582214] EFI Variables Facility v0.08 2004-May-17
[ 0.582656] TCP cubic registered
[ 0.582873] NET: Registered protocol family 10
[ 0.583838] NET: Registered protocol family 17
[ 0.583872] Registering the dns_resolver key type
[ 0.583911] Using IPI No-Shortcut mode
[ 0.588384] PM: Hibernation image not present or could not be loaded.
[ 0.588420] registered taskstats version 1
[ 0.832751] ata2.01: NODEV after polling detection
[ 0.832942] ata1.00: ATA-6: HTS541040G9AT00, MB2OA60A, max UDMA/100
[ 0.832947] ata1.00: 78140160 sectors, multi 16: LBA48
[ 0.840866] ata2.00: ATAPI: UJDA760 DVD/CDRW, 1.00, max UDMA/33
[ 0.841249] ata1.00: configured for UDMA/100
[ 0.884841] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.885205] ata2.00: configured for UDMA/33
[ 0.935620] isapnp: No Plug & Play device found
[ 0.935952] scsi 0:0:0:0: Direct-Access ATA HTS541040G9AT00 MB2O PQ: 0 ANSI: 5
[ 0.936326] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 0.936598] sd 0:0:0:0: [sda] 78140160 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 0.936673] sd 0:0:0:0: [sda] Write Protect is off
[ 0.936678] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.936710] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 0.973785] scsi 1:0:0:0: CD-ROM MATSHITA UJDA760 DVD/CDRW 1.00 PQ: 0 ANSI: 5
[ 0.975892] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[ 0.975899] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 0.976187] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 0.976409] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.037322] sda: sda1 sda2 < sda5 sda6 sda7 >
[ 1.038130] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.044341] hub 1-0:1.0: over-current condition on port 1
[ 1.222914] Freeing initrd memory: 13792k freed
[ 1.247675] Magic number: 0:990:538
[ 1.247740] tty ttyS18: hash matches
[ 1.247857] rtc_cmos 00:01: setting system clock to 2016-01-26 15:31:47 UTC (1453822307)
[ 1.247903] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20110623/processor_perflib-318)
[ 1.247917] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.247919] EDD information not available.
[ 1.248193] Freeing unused kernel memory: 712k freed
[ 1.248764] Write protecting the kernel text: 5632k
[ 1.248826] Write protecting the kernel read-only data: 2324k
[ 1.252159] hub 1-0:1.0: over-current condition on port 2
[ 1.280203] udevd[86]: starting version 175
[ 1.460098] hub 2-0:1.0: over-current condition on port 1
[ 1.523369] b44 0000:02:02.0: PCI INT A -> Link[LNKD] -> GSI 6 (level, low) -> IRQ 6
[ 1.568161] ssb: Core 0 found: Fast Ethernet (cc 0x806, rev 0x04, vendor 0x4243)
[ 1.568171] ssb: Core 1 found: V90 (cc 0x807, rev 0x01, vendor 0x4243)
[ 1.568178] ssb: Core 2 found: PCI (cc 0x804, rev 0x02, vendor 0x4243)
[ 1.608352] ssb: Sonics Silicon Backplane found on PCI device 0000:02:02.0
[ 1.608389] b44: Broadcom 44xx/47xx 10/100 PCI ethernet driver version 2.0
[ 1.629396] b44 ssb0:0: eth0: Broadcom 44xx/47xx 10/100 PCI ethernet driver 00:c0:9f:5d:b9:27
[ 1.668067] hub 2-0:1.0: over-current condition on port 2
[ 1.981193] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 28.394863] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 28.455212] udevd[301]: starting version 175
[ 28.523111] lp: driver loaded but no devices found
[ 28.533070] Adding 750588k swap on /dev/sda7. Priority:-1 extents:1 across:750588k
[ 28.770971] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
[ 28.922264] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[ 28.946139] acpi device:05: registered as cooling_device3
[ 28.946386] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/LNXVIDEO:00/input/input4
[ 28.950157] ACPI: Video Device [GFX0] (multi-head: yes rom: yes post: no)
[ 29.099176] RPC: Registered named UNIX socket transport module.
[ 29.099183] RPC: Registered udp transport module.
[ 29.099186] RPC: Registered tcp transport module.
[ 29.099189] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 29.120263] FS-Cache: Loaded
[ 29.205134] FS-Cache: Netfs ‘nfs’ registered for caching
[ 29.336746] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 29.337807] Bluetooth: Core ver 2.16
[ 29.337856] NET: Registered protocol family 31
[ 29.337859] Bluetooth: HCI device and connection manager initialized
[ 29.337865] Bluetooth: HCI socket layer initialized
[ 29.337868] Bluetooth: L2CAP socket layer initialized
[ 29.337876] Bluetooth: SCO socket layer initialized
[ 29.357107] [drm] Initialized drm 1.1.0 20060810
[ 29.365389] ppdev: user-space parallel port driver
[ 29.443933] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 29.443939] Bluetooth: BNEP filters: protocol multicast
[ 29.449371] ACPI: SBS HC: EC = 0xecca5840, offset = 0x18, query_bit = 0x20
[ 29.658119] type=1400 audit(1453818735.907:2): apparmor=“STATUS” operation=“profile_load” name=“/usr/lib/cups/backend/cups-pdf” pid=586 comm=“apparmor_parser”
[ 29.663403] type=1400 audit(1453818735.911:3): apparmor=“STATUS” operation=“profile_load” name=“/usr/sbin/cupsd” pid=586 comm=“apparmor_parser”
[ 29.686837] intel_rng: FWH not detected
[ 29.691378] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 29.800339] init: portmap-wait (statd) main process (596) killed by TERM signal
[ 29.887741] init: statd-mounting main process (505) killed by TERM signal
[ 30.115542] yenta_cardbus 0000:02:06.0: CardBus bridge found [1025:0064]
[ 30.115561] yenta_cardbus 0000:02:06.0: Enabling burst memory read transactions
[ 30.115567] yenta_cardbus 0000:02:06.0: Using CSCINT to route CSC interrupts to PCI
[ 30.115571] yenta_cardbus 0000:02:06.0: Routing CardBus interrupts to PCI
[ 30.115577] yenta_cardbus 0000:02:06.0: TI: mfunc 0x01a21b22, devctl 0x64
[ 30.218047] i915 0000:00:02.0: PCI INT A -> Link[LNKA] -> GSI 6 (level, low) -> IRQ 6
[ 30.218057] i915 0000:00:02.0: setting latency timer to 64
[ 30.255054] type=1400 audit(1453818736.503:4): apparmor=“STATUS” operation=“profile_load” name=“/sbin/dhclient” pid=673 comm=“apparmor_parser”
[ 30.255832] type=1400 audit(1453818736.503:5): apparmor=“STATUS” operation=“profile_load” name=“/usr/lib/NetworkManager/nm-dhcp-client.action” pid=673 comm=“apparmor_parser”
[ 30.266264] ACPI: Deprecated procfs I/F for SBS is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[ 30.268290] ACPI: Smart Battery System [SBS0]: AC Adapter [AC0] (on-line)
[ 30.273694] type=1400 audit(1453818736.523:6): apparmor=“STATUS” operation=“profile_load” name=“/usr/lib/connman/scripts/dhclient-script” pid=673 comm=“apparmor_parser”
[ 30.348710] yenta_cardbus 0000:02:06.0: ISA IRQ mask 0x08b8, PCI irq 10
[ 30.348718] yenta_cardbus 0000:02:06.0: Socket status: 30000006
[ 30.348724] pci_bus 0000:02: Raising subordinate bus# of parent bus (#02) from #02 to #06
[ 30.348739] yenta_cardbus 0000:02:06.0: pcmcia: parent PCI bridge window: [io 0x3000-0x3fff]
[ 30.348745] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3000-0x3fff: excluding 0x3000-0x30ff 0x3400-0x34ff
[ 30.412746] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 30.412751] [drm] Driver supports precise vblank timestamp query.
[ 30.414919]
[ 30.414930] yenta_cardbus 0000:02:06.0: pcmcia: parent PCI bridge window: [mem 0xe0200000-0xe05fffff]
[ 30.414937] pcmcia_socket pcmcia_socket0: cs: memory probe 0xe0200000-0xe05fffff: excluding 0xe0200000-0xe023ffff
[ 30.414954] yenta_cardbus 0000:02:06.0: pcmcia: parent PCI bridge window: [mem 0x34000000-0x39ffffff pref]
[ 30.414959] pcmcia_socket pcmcia_socket0: cs: memory probe 0x34000000-0x39ffffff: excluding 0x34000000-0x39ffffff
[ 30.428147] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 30.512424] fixme: max PWM is zero.
[ 31.103728] [drm] initialized overlay support
[ 31.111151] psmouse serio4: synaptics: Touchpad model: 1, fw: 5.9, id: 0x126eb1, caps: 0xa04713/0x4000/0x0
[ 31.190311] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input5
[ 31.289466] init: failsafe main process (744) killed by TERM signal
[ 31.812582] type=1400 audit(1453818738.063:7): apparmor=“STATUS” operation=“profile_load” name=“/usr/share/gdm/guest-session/Xsession” pid=850 comm=“apparmor_parser”
[ 31.852116] type=1400 audit(1453818738.103:8): apparmor=“STATUS” operation=“profile_load” name=“/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper” pid=851 comm=“apparmor_parser”
[ 31.863402] type=1400 audit(1453818738.111:9): apparmor=“STATUS” operation=“profile_replace” name=“/sbin/dhclient” pid=857 comm=“apparmor_parser”
[ 31.874204] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 31.882381] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 31.885711] type=1400 audit(1453818738.135:10): apparmor=“STATUS” operation=“profile_replace” name=“/usr/lib/NetworkManager/nm-dhcp-client.action” pid=857 comm=“apparmor_parser”
[ 31.886183] type=1400 audit(1453818738.135:11): apparmor=“STATUS” operation=“profile_replace” name=“/usr/lib/connman/scripts/dhclient-script” pid=857 comm=“apparmor_parser”
[ 31.903751] fbcon: inteldrmfb (fb0) is primary device
[ 31.906734] Console: switching to colour frame buffer device 128x48
[ 31.906787] fb0: inteldrmfb frame buffer device
[ 31.906790] drm: registered panic notifier
[ 31.906865] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 31.906936] snd_intel8x0 0000:00:1f.5: PCI INT B -> Link[LNKB] -> GSI 10 (level, low) -> IRQ 10
[ 31.906982] snd_intel8x0 0000:00:1f.5: setting latency timer to 64
[ 32.160384] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: excluding 0x170-0x177 0x1c0-0x1cf 0x1f0-0x1f7 0x370-0x377
[ 32.161974] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: excluding 0x3f0-0x3f7 0x4d0-0x4d7
[ 32.162652] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 32.163213] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 32.163834] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff: excluding 0xc0000-0xc7fff 0xcc000-0xcffff 0xdc000-0xfffff
[ 32.163874] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: clean.
[ 32.163913] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff: clean.
[ 32.163950] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 32.272069] intel8x0_measure_ac97_clock: measured 53770 usecs (2591 samples)
[ 32.272076] intel8x0: clocking to 48000
[ 33.409772] init: gdm main process (998) killed by TERM signal
[ 34.208070] ACPI: Deprecated procfs I/F for SBS is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[ 34.208379] ACPI: Smart Battery System [SBS0]: Battery Slot [BAT0] (battery present)
[ 393.476058] usb 3-2: new full-speed USB device number 2 using uhci_hcd
[ 393.596053] usb 3-2: device descriptor read/64, error -71
[ 393.820060] usb 3-2: device descriptor read/64, error -71
[ 394.036053] usb 3-2: new full-speed USB device number 3 using uhci_hcd
[ 394.156043] usb 3-2: device descriptor read/64, error -71
[ 394.380045] usb 3-2: device descriptor read/64, error -71
[ 394.596045] usb 3-2: new full-speed USB device number 4 using uhci_hcd
[ 395.004038] usb 3-2: device not accepting address 4, error -71
[ 395.116051] usb 3-2: new full-speed USB device number 5 using uhci_hcd
[ 395.524046] usb 3-2: device not accepting address 5, error -71
[ 395.524066] hub 3-0:1.0: unable to enumerate USB device on port 2
[ 477.556261] usb 1-3: new high-speed USB device number 3 using ehci_hcd
[ 477.782620] Initializing USB Mass Storage driver…
[ 477.784618] scsi2 : usb-storage 1-3:1.0
[ 477.784784] usbcore: registered new interface driver usb-storage
[ 477.784788] USB Mass Storage support registered.
[ 477.817462] usbcore: registered new interface driver uas
[ 478.784951] scsi 2:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 478.790873] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 478.792545] sd 2:0:0:0: [sdb] 262144000 512-byte logical blocks: (134 GB/125 GiB)
[ 478.793444] sd 2:0:0:0: [sdb] Write Protect is off
[ 478.793452] sd 2:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 478.793923] sd 2:0:0:0: [sdb] No Caching mode page present
[ 478.793930] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 478.796507] sd 2:0:0:0: [sdb] No Caching mode page present
[ 478.796516] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 478.800788] sdb: unknown partition table
[ 478.803822] sd 2:0:0:0: [sdb] No Caching mode page present
[ 478.803832] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 478.803838] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 497.985826] usb 1-3: USB disconnect, device number 3
[ 497.996194] sd 2:0:0:0: [sdb] Unhandled error code
[ 497.996203] sd 2:0:0:0: [sdb] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 497.996210] sd 2:0:0:0: [sdb] CDB: Write(10): 2a 00 00 5d 3b 78 00 00 f0 00
[ 497.996224] end_request: I/O error, dev sdb, sector 6110072
[ 497.996233] quiet_error: 45 callbacks suppressed
[ 497.996237] Buffer I/O error on device sdb, logical block 6110072
[ 497.996240] lost page write due to I/O error on sdb
[ 497.996247] Buffer I/O error on device sdb, logical block 6110073
[ 497.996250] lost page write due to I/O error on sdb
[ 497.996253] Buffer I/O error on device sdb, logical block 6110074
[ 497.996256] lost page write due to I/O error on sdb
[ 497.996260] Buffer I/O error on device sdb, logical block 6110075
[ 497.996263] lost page write due to I/O error on sdb
[ 497.996266] Buffer I/O error on device sdb, logical block 6110076
[ 497.996269] lost page write due to I/O error on sdb
[ 497.996272] Buffer I/O error on device sdb, logical block 6110077
[ 497.996275] lost page write due to I/O error on sdb
[ 497.996279] Buffer I/O error on device sdb, logical block 6110078
[ 497.996282] lost page write due to I/O error on sdb
[ 497.996285] Buffer I/O error on device sdb, logical block 6110079
[ 497.996288] lost page write due to I/O error on sdb
[ 497.996302] Buffer I/O error on device sdb, logical block 6110080
[ 497.996305] lost page write due to I/O error on sdb
[ 497.996308] Buffer I/O error on device sdb, logical block 6110081
[ 497.996311] lost page write due to I/O error on sdb
[ 498.074376] VFS: busy inodes on changed media or resized disk sdb
[ 498.264589] init: ureadahead-other main process (2004) terminated with status 2
[ 607.368252] usb 1-4: new high-speed USB device number 4 using ehci_hcd
[ 607.506847] scsi3 : usb-storage 1-4:1.0
[ 608.504954] scsi 3:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 608.511230] sd 3:0:0:0: Attached scsi generic sg2 type 0
[ 608.511683] sd 3:0:0:0: [sdb] 262144000 512-byte logical blocks: (134 GB/125 GiB)
[ 608.513211] sd 3:0:0:0: [sdb] Write Protect is off
[ 608.513219] sd 3:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 608.513812] sd 3:0:0:0: [sdb] No Caching mode page present
[ 608.513819] sd 3:0:0:0: [sdb] Assuming drive cache: write through
[ 608.517310] sd 3:0:0:0: [sdb] No Caching mode page present
[ 608.517319] sd 3:0:0:0: [sdb] Assuming drive cache: write through
[ 608.521572] sdb: unknown partition table
[ 608.524793] sd 3:0:0:0: [sdb] No Caching mode page present
[ 608.524801] sd 3:0:0:0: [sdb] Assuming drive cache: write through
[ 608.524807] sd 3:0:0:0: [sdb] Attached SCSI removable disk
[ 635.375533] usb 1-4: USB disconnect, device number 4
[ 648.280053] usb 3-2: new full-speed USB device number 6 using uhci_hcd
[ 648.400054] usb 3-2: device descriptor read/64, error -71
[ 648.624049] usb 3-2: device descriptor read/64, error -71
[ 648.840046] usb 3-2: new full-speed USB device number 7 using uhci_hcd
[ 648.960048] usb 3-2: device descriptor read/64, error -71
[ 649.184177] usb 3-2: device descriptor read/64, error -71
[ 649.400045] usb 3-2: new full-speed USB device number 8 using uhci_hcd
[ 649.808041] usb 3-2: device not accepting address 8, error -71
[ 649.920048] usb 3-2: new full-speed USB device number 9 using uhci_hcd
[ 650.328055] usb 3-2: device not accepting address 9, error -71
[ 650.328087] hub 3-0:1.0: unable to enumerate USB device on port 2
[ 677.740062] usb 3-1: new full-speed USB device number 10 using uhci_hcd
[ 677.860036] usb 3-1: device descriptor read/64, error -71
[ 678.084050] usb 3-1: device descriptor read/64, error -71
[ 678.300047] usb 3-1: new full-speed USB device number 11 using uhci_hcd
[ 678.420048] usb 3-1: device descriptor read/64, error -71
[ 678.644051] usb 3-1: device descriptor read/64, error -71
[ 678.860052] usb 3-1: new full-speed USB device number 12 using uhci_hcd
[ 679.268038] usb 3-1: device not accepting address 12, error -71
[ 679.380048] usb 3-1: new full-speed USB device number 13 using uhci_hcd
[ 679.788062] usb 3-1: device not accepting address 13, error -71
[ 679.788093] hub 3-0:1.0: unable to enumerate USB device on port 1
[ 822.952256] usb 1-4: new high-speed USB device number 7 using ehci_hcd
[ 823.090378] scsi4 : usb-storage 1-4:1.0
[ 824.088967] scsi 4:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 824.094985] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 824.095432] sd 4:0:0:0: [sdb] 262144000 512-byte logical blocks: (134 GB/125 GiB)
[ 824.096964] sd 4:0:0:0: [sdb] Write Protect is off
[ 824.096973] sd 4:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 824.097563] sd 4:0:0:0: [sdb] No Caching mode page present
[ 824.097570] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 824.101159] sd 4:0:0:0: [sdb] No Caching mode page present
[ 824.101168] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 824.105570] sdb: unknown partition table
[ 824.108917] sd 4:0:0:0: [sdb] No Caching mode page present
[ 824.108924] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 824.108930] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 1026.440982] usb 1-4: USB disconnect, device number 7
[ 1102.712254] usb 1-4: new high-speed USB device number 8 using ehci_hcd
[ 1102.848230] scsi5 : usb-storage 1-4:1.0
[ 1103.848958] scsi 5:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 1103.853841] sd 5:0:0:0: Attached scsi generic sg2 type 0
[ 1103.853928] sd 5:0:0:0: [sdb] 262144000 512-byte logical blocks: (134 GB/125 GiB)
[ 1103.854421] sd 5:0:0:0: [sdb] Write Protect is off
[ 1103.854428] sd 5:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 1103.854911] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1103.854917] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1103.858430] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1103.858439] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1103.861415] sdb: unknown partition table
[ 1103.863662] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1103.863668] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1103.863672] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[ 1196.004901] usb 1-4: USB disconnect, device number 8
[ 1325.872257] usb 1-4: new high-speed USB device number 9 using ehci_hcd
[ 1326.010393] scsi6 : usb-storage 1-4:1.0
[ 1327.008949] scsi 6:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 1327.014938] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 1327.016500] sd 6:0:0:0: [sdb] 262144000 512-byte logical blocks: (134 GB/125 GiB)
[ 1327.017031] sd 6:0:0:0: [sdb] Write Protect is off
[ 1327.017037] sd 6:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 1327.017537] sd 6:0:0:0: [sdb] No Caching mode page present
[ 1327.017544] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1327.019916] sd 6:0:0:0: [sdb] No Caching mode page present
[ 1327.019925] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1327.024438] sdb: unknown partition table
[ 1327.026773] sd 6:0:0:0: [sdb] No Caching mode page present
[ 1327.026781] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1327.026787] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 1584.130397] usb 1-4: USB disconnect, device number 9
[ 1619.284056] usb 1-4: new high-speed USB device number 10 using ehci_hcd
[ 1619.424172] scsi7 : usb-storage 1-4:1.0
[ 1620.428593] scsi 7:0:0:0: Direct-Access CBM2080 Flash Disk 2.00 PQ: 0 ANSI: 2
[ 1620.431943] sd 7:0:0:0: [sdc] 254976 512-byte logical blocks: (130 MB/124 MiB)
[ 1620.432697] sd 7:0:0:0: [sdc] Write Protect is off
[ 1620.432703] sd 7:0:0:0: [sdc] Mode Sense: 0b 00 00 08
[ 1620.432951] sd 7:0:0:0: Attached scsi generic sg2 type 0
[ 1620.433194] sd 7:0:0:0: [sdc] No Caching mode page present
[ 1620.433200] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[ 1620.437333] sd 7:0:0:0: [sdc] No Caching mode page present
[ 1620.437343] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[ 1620.438448] sdc: sdc1
[ 1620.441186] sd 7:0:0:0: [sdc] No Caching mode page present
[ 1620.441194] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[ 1620.441201] sd 7:0:0:0: [sdc] Attached SCSI removable disk
[ 1684.720186] usb 1-4: USB disconnect, device number 10
[ 1865.744063] usb 1-4: new high-speed USB device number 11 using ehci_hcd
[ 1865.884080] scsi8 : usb-storage 1-4:1.0
[ 1866.888567] scsi 8:0:0:0: Direct-Access CBM2080 Flash Disk 2.00 PQ: 0 ANSI: 2
[ 1866.891907] sd 8:0:0:0: [sdc] 254976 512-byte logical blocks: (130 MB/124 MiB)
[ 1866.892413] sd 8:0:0:0: [sdc] Write Protect is off
[ 1866.892420] sd 8:0:0:0: [sdc] Mode Sense: 0b 00 00 08
[ 1866.893208] sd 8:0:0:0: [sdc] No Caching mode page present
[ 1866.893216] sd 8:0:0:0: [sdc] Assuming drive cache: write through
[ 1866.895079] sd 8:0:0:0: Attached scsi generic sg2 type 0
[ 1866.896541] sd 8:0:0:0: [sdc] No Caching mode page present
[ 1866.896549] sd 8:0:0:0: [sdc] Assuming drive cache: write through
[ 1866.898180] sdc: sdc1
[ 1866.901162] sd 8:0:0:0: [sdc] No Caching mode page present
[ 1866.901170] sd 8:0:0:0: [sdc] Assuming drive cache: write through
[ 1866.901176] sd 8:0:0:0: [sdc] Attached SCSI removable disk
[ 1995.605305] usb 1-4: USB disconnect, device number 11
Can you try using a new sd card and setting it up fresh ? http://smoothieware.org/sd-card
Hi arthurwolf
I formated a new sd card (FAT32) and saved config + firmware.bin from smoothieware_org/sd-card.
But still the same, every thing else is working fine, I can print and the display is working.
This is extremely strange.
I’m not sure what’s going on, I’ll give some time for somebody with better USB knowledge to come in and advise. Could you use Ethernet in the meantime ? If nobody chimes in soon, post here again please.
Yes, it is strange.
I will take a look at ethernet, thank you for your time.
