Using GRBL 1.1f with LW4. Running in to an issue. Every so often, when trying to connect, it states that “no supported firmware detected”. The only way to get it out of this is to reflash the firmware , and do all the settings again.
Has anyone else had this issue?
When it works, it work great. This has happened 5 times today.
Ok, this has happened 2 more times this morning, however under different circumstances. This time literally just sitting there idle. It lost connection, and will not reconnect as it does not find supported firmware. It takes a re-flash for LW4 to recognize and connect again. Again , LW3, and a terminal still connect just fine.
@Eric_Flynn is this grbl-lpc or the arduino? Which OS? I’m starting to wonder if some other process or maybe the OS driver is eating the startup message.
We can test the OS eating it: @Eric_Flynn try opening and closing your terminal several times. You should see a message from GRBL each time. Are you using PuTTY or something else?
