Using insulation styrofoam for led matrix, looks very nice, gotta try that
@Philippe_Maegerman in a previous post here, I wrote:
You might want to try using Polyiso Rigid Foam Insulation Board (1/2 in. x 4 ft. x 8 ft., Store SKU # 754404) from Home Depot. It is inexpensive and will hold your 12mm RGB LED pixels in place. I know because I tried it with similar RGB LED pixels. See :
When I did this, I tried using a lab cork borer to make the holes but this ripped some of the foil on the board. A hand drill worked better.
@Ken_White Sweet
I liked the fact that itโs black, it seems to absorb the light and diffuse it a little bit at the same time, maybe due to the camera though.
