V1.52 has been released 3D Printing from any Android device - PC less printing
gcodeprintr V1.52 has been released
*Connect to a printer using USB OTG/Host port
*Supports wireless printing over Bluetooth
*Touch screen printer control interface (X,Y,Z Movement, Heat, Fan,…)
*Layer by layer visualization and print simulation
*Show details like estimated time, speeds, filament usage, cost,…
*Printing is done in background (Android service)
*Small web interface to remotely view print status.
*Receive print object from PC over network
*Works with many 3D printers and multiple firmwares (Sprinter,Marlin,…)
Homepage: http://gcodeprintr.dietzm.de
Google Play: https://play.google.com/store/apps/details?id=de.dietzm.gcodesimulatorprinter
GCodePrintr was previously known as #GCodeSimulator &Printer and has been renamed recently
V1.52 changes
  • GCodeSimulator&Printer renamed to GCodePrintr
  • New 3D app icon and logo made with openSCAD.
    Printing is done by an Android background service
  • Once connected, a service is started to handle the connection.
  • Print jobs will be done by the service, the App itself can be closed.
  • Print progress is shown on the notification panel (% complete + time remaining)
  • Click on the notification, will open up the App and sync up with the service.
  • Printer connection can be closed by pressing X on the notification (be careful, it will stop your print )
    Rudimentary webserver to view the print status with a web browser
  • Connect to the webserver using the Androids device IP with port 2323.
  • Stop/Pause a print over the web interface
  • Start/Stop IP Webcam over Webinterface (Using IP Webcam App)
  • web server depends on the printer service and is only active when the service is started.
    Many bug fixes and smaller improvement
  • some (experimental) Makibox improvements
  • Option to save gcode files which have been received wirelessly. (Requires Permission to write to external storage)
  • Option to write a full communication log to sd card (for debugging)
  • Removed status bar option (statusbar is always on now)
  • Show Print status text on status bar
  • Makergear M2 / Rambo board support
