Well unfortunately for me, my K40 seems to stay on the top Y line when I try to vector cut. The rasters work fine in both X and Y directions…?? Checked, nothing outside the boundry.
If you post your SVG or send the SVG to the e-mail address in the K40 Whisperer help menu I can take a look at it.
Or you could try running the sample file from the K40 Whisperer manual to see how that goes:
http://www.scorchworks.com/K40whisperer/k40_whisperer_test.svg
Scorch
…kinda of embarrassing…but I didn’t see the forest because of the trees. I had set the Board Name as just Laser-M. Should have been Laser-M2. Changed that and now it works for vector cuts.
