Vectric users:
If I add vectric products to a bundle do I add Aspire? Or is the pro and desktop sufficient?
Pro is what I use… I didn’t see the percentage to justify the cost for Aspire.
The 3d stuff aspire does is cool, but vcarve makes way more money for me.
I use Aspire.
Thank you guys! My R7 peeps are always my focus. You guys allow me to be a stepping stone to your greatness.
@raykholo to lay out PCBs?
No no, when I need to cnc or laser cut engineering parts, mostly 2 or 2.5d plates for machines in the past when I had the time to work on such fun things.
The shapeoko (mm) postprocessor for Vectric worked nicely for tinyg and smoothie on my CNC’s and then I rewrote that PP for laser cutting on smoothie.
@raykholo nice.
Aspire is for 3d. You can upgrade to aspire from pro. I think pro is 600 and aspire is 1200. If you upgrade to aspire from pro it will cost 700. I went with pro and figured if I wanted aspire it would only cost me an additional 700. Pro will still carve 3d but it will not create 3d. You have to import it.
