Vectric Vcarve Desktop Hi all I am interested in getting Vectric Vcarve Desktop and
Hi all
I am interested in getting Vectric Vcarve Desktop and would like to know which post processor I should use with Chilipeppr/Tinyg.
Does Vcarve already have a post processor package that is compatable or does anyone know of a compatable post processor that I can download for Vcarve?
Thanks
I have a post processor you could use… I have one that allows arcs (G2,G3) movements and another that forces arcs to be interpreted as G1 movements
@Alex_Krause I would like to have that if you dont mind I also have a problem that when I send the gcode to CP using “Gcode (mm).tap” post processor my feeds and speeds are all out of wack. They are much to fast. Also when loading the file in to cp it ask if it is inches or mm not sure if that could be an issue
@snooper_ace ​ are you setting your feed rate as Mm/min or mm/sec
