Velocity Painting – have a go
I’ve just released the STL, image, instructions and processed Prusa i3 MK2 GCODE for my Vase With Climbing rose
There’s an app available so why not have a go yourself?
All at http://www.velocitypainting.xyz #VelocityPainting #3DPrinting
https://www.velocitypainting.xyz/blog/vase-with-climbing-rose/
Wow, what started as an experiment of sorts is really taking 3d printing by a storm!! Congrats and what a great idea #velocitypainting is
This is a wonderful technique and expands the possibilities greatly, well done Mark. Most, if not all the models I’ve seen so far have the pattern on the sides of the object, is there a way to do this on the top or bottom faces instead ?
@Rob_Wilson Absolutely, yes. Just use projectZ rather than projectX or projectY.
Thanks muchly Mark, I just installed Repetier Host 2.0.1, and now I’ve looked at it more closely I’ve noticed the “Project on X-Y Plane” under the “Projection Method” drop-down, brilliant.
