Version V1.36 of #GCodeSimulator & Printer is released with a new look and many improvements.
Thanks to all beta testers for the feedback.
V1.36 Changes
Theme support with 2 new themes (Autumn and Gray)
Antialiasing for smoother rendering
New print status bar
Files can be opened from Google Drive
Support for Vendor ID 0x03eb (AMTEL) used in Robo3D printers.
Improved GCode load times (optimized float conversion and split function)
Send custom command to printer
Use touch screen to move printer head (experimental)
Set speed factor override (M220) (experimental)
Fixed handling of “unknown” gcodes
New settings:
Communication timeout option
Option to disable rendering during print (to save CPU time)
Options to flip X / Y manual movement
Increase heap memory when loading files to speedup load times(experimental)
Debugability improvements:
New debug status output (pressing pause while in debug mode)
Show timeouts,swallowOK,unexpected responses,garbage collector time,…
Include settings in support email
Improved Bluetooth debug (retry sending M105)
Please note It will take some hours until the update is pushed to all Google servers.
