Want to play with the noise functions more? I’ve just pushed new code to the FastLED2.1 branch that includes fill functions for both 8 and 16 bit noise - both for filling raw noise values into an array of 8-bit data as well as for setting led colorings.
There’s also a new example, called NoisePlayground. It’s basically a refined version of the code that I used for the videos I posted earlier. There’s a number of variable values that you can change/play with to mess with what the noise functions are doing. I’ve included a set of default values that I’ve found entertaining on a 16x16 array. Hopefully this will provide a fun starting point for folks to play with.
Right now, it is setup for a 16x16 led matrix. but you can change it to support other types of setups. I’ll modify the example for easily switching to 1-d layouts tomorrow. I still need sleep, and hoping that I can do that soon.
I’d be lying if I said I hadn’t just spent the last hour playing with it.
Where did the frame rate in the serial monitor come from? Is this also a new feature?
Ah - yes, if you look in loop, there’s a call to LEDS.countFPS - it’s a bit raw and clunky but I’m hoping to refine it a bit more over time.
I really need to get my hands on a 16x16 matrix, my little 8x8 is just too small to get any distinct visual patterns. Do you have any suggestions?
Play with the numbers - I suspect you can get stuff out of even an 8x8.
Cut the scale factors in half, for example.
After doing 2 weeks different stuff it’s amazing to come back here and see the awesome noise functions in action. I’d love to play with it! Where can I find the NoisePlayground Example sketch and the new FastLED2.1 branch?
https://github.com/FastLED/FastLED/tree/FastLED2.1
In Github, look for the “Branch” pull down menu, and you will find the different versions.
