wanting to get a 3d printer …don’t wanna go to small whats a good printer I don’t mind having to build it as a kit if it saves me a buck or two
any info is greatly appreciated I advance…buying used could be a option too
You could consider:
For US$970.
Awesome specs vs price point.
I have a CraftBot 1st generation.
Thank you I will check it out
@Ivan_Hoe just don’t wanna go small and get board 2 months later and want a bigger one
If you want something cheap there are numerous prusa i3 kits on ebay. Such as the folgertech. I would check that one out as well
get a prusa i3, nice and simple with a good build area
@zephyrin_JG thank you I will check it out
I have a he3d branded one, needed a few mods but now its awesome
nice thank you for your inputs after work I will check out these suggestions and youtube some videos on them
theres not much info on the he3d stuff though
@Brad_V , good luck on your DIY search.
thanks guys
Mendel 90? Designed by Nophead, hackable, well regarded among the community, and E3D (@Sanjay_Mortimer )even use these test their hotends.
It’s a bit “fiddly” to put together, but should get you good results
Printrbot Simple Metal is a good printer. That is what I’ve started with. It will do 6x6x6 inches. There is a upgrade available from Matrix Precision to allow you to print 8X8X10 inches for about $200. I highly recommend it.
I wish I had a second Printrbot Simple Metal so I could use it while I’m printing a 8-24 hour job on my other Printrbot Simple Metal.
Kossel (delta type) printers can be bought really big for cheap. try the Kossel xl on http://hkbay.com
Also rigidbot seems good and expandable.
Have a look @ " TeeBot"The suitcase 3D printer. http://www.3dstuffs.nl/teebot currently on kick-stater as a KIT or fully assemble and it is opendesign. https://www.kickstarter.com/projects/99905999/teebot-the-suitcase-3d-printer
@3D_ZPrinting I would like to be able to learn and adjust and be able to tweak when I reach that level just don’t wanna by cheap basic and the have to buy something everytime…if that makes sense
