Was the BLTouch figured out correctly?
Was the BLTouch figured out correctly? (I know I ask every few months) I read there might be a plugin coming to make it work easier though @Elias_Bakken ; I would love to switch to it if getting it to work is possible now.
I added a BL touch a few weeks ago to another printer with a RUMBA board and it works great.
It is really a popular device a it would be great to get it working with Replicape and Redeem
I started the tests with BLTouch. To drive it correctly I put these values:
[Endstops]
end_stop_delay_cycles = 500
[Servos]
servo_0_enable = True
servo_0_angle_init = 90
servo_0_angle_min =0
servo_0_angle_max = 180
servo_0_pulse_min = 0.0005
servo_0_pulse_max = 0.0025
M280 P0 S10 F5000 R ; Pin Down
M280 P0 S90 F5000 R ; Pin Up
that is great info, I don’t have a touch atm but if anyone else chimes in saying it works for them then I’ll assume it is safe to go buy one and add it to my machine.
Appreciate it.
Furax Gromov, you are the man! I just installed a BLTouch and your configuration works perfectly! I’m going to add a How-To to our wiki, and I’ll be sure to mention you!
