Water absorption can be a problem when printing with nylon, but fear not:
Water absorption can be a problem when printing with nylon, but fear not: there are some easy steps you may take to completely reverse water damaged filament.
http://blog.blackmagic3d.com/taulman-nylons-prevent-moisture-damage/
“Drying nylon materials before using them for printing will remove almost all of the water molecules. You may use a blow dryer for this, or some desiccant packets.”
That’s all the advice they have? For me that simply wasn’t sufficient in any way. Ultimately i had to dry the spools in an oven for a couple of hours before printing. Especially the blowdryer is a no go, you would need hours and it is inefficient.
