Well I had a thought about my K40 (which has the potentiometer for adjusting the power) & I realised that there is no way to really tell where exactly your power setting is at as nothing is marked (except pencil lines I have drawn on my machine haha).
So I measured up the knob, that is on top of the pot, checked positioning for 0 & 100%. Turns out the knob is 25mm diameter and the 0% position is at 0 degrees (the bottom of circle) & 100% is at 270 degrees (the right of circle). So basically 27 degree steps for 0-100.
So here I’ve designed up a label that can slide over the knob. Centre hole will be 26mm diameter (so we have ~1mm of space away from the knob) & the entire thing will be 59.631mm diameter (according to Adobe Illustrator’s calculations).
Feel free to use if you also would like to be able to determine your power % position.
