Well this looks pretty good lol
What kind of sensor are you using?
@marmil im using a sparkfun electret microphone sensor and an adafruit gemma. But this is just a prototype. The sensitivity of the microphe is way too high. Plus the bootloader on the gemma only gives me 5kb to work with. Im gonna play around with resistor values to reduce the sensitivity of the microphone in the hardware using one of my boards i have laying around. I have to find an use for the 75 i have left. Lighting up a drumset seems like a good cause lol
Very cool. Looking forward to seeing more as it progresses.
Curious if you have tried using a piezo as a pickup?
Yeah trying to convice the pastor at my church to let me put LEDs in the drums. He said not to spend too much and we can give it a try. DIY is definitely the cheapest approach lol
I have not. But the end goal is to have the drum act like a VU meter. But as it is right now it picks up my voice from 5 feet away. So all the cool effects other than the falling dot are drowned out in the noise
@Jon_Burroughs , any suggestions you might be able to provide?
try using this to trigger your LED animations, mic’s are often way too sensitive, i always have used piezo triggers.
@Jon_Burroughs thanx man!
Guys while we’re on the subject. The code for this is based on the code for Adafruit’s Ursula’s seashell necklace. But it dynamically adjusts to the current sound level. I want to have it run without dynamically adjusting. Similar to the code for the ampli-tie. But since im using a gemma i only have 5KB to work with and the ampli-tie code takes up 119% of that. Any help?
//Non-dynamic ampli-tie code
LED VU meter for Arduino and Adafruit NeoPixel LEDs.
Hardware requirements:
- Most Arduino or Arduino-compatible boards (ATmega 328P or better).
- Adafruit Electret Microphone Amplifier (ID: 1063)
- Adafruit Flora RGB Smart Pixels (ID: 1260)
OR - Adafruit NeoPixel Digital LED strip (ID: 1138)
- Optional: battery for portable use (else power through USB or adapter)
Software requirements: - Adafruit NeoPixel library
Connections:
- 3.3V to mic amp +
- GND to mic amp -
- Analog pin to microphone output (configurable below)
- Digital pin to LED data input (configurable below)
See notes in setup() regarding 5V vs. 3.3V boards - there may be an
extra connection to make and one line of code to enable or disable.
Written by Adafruit Industries. Distributed under the BSD license.
This paragraph must be included in any redistribution.
fscale function:
Floating Point Autoscale Function V0.1
Written by Paul Badger 2007
Modified from code by Greg Shakar
#include <Adafruit_NeoPixel.h>
#include <math.h>
#define N_PIXELS 16 // Number of pixels in strand
#define MIC_PIN A9 // Microphone is attached to this analog pin
#define LED_PIN 6 // NeoPixel LED strand is connected to this pin
#define SAMPLE_WINDOW 10 // Sample window for average level
#define PEAK_HANG 24 //Time of pause before peak dot falls
#define PEAK_FALL 4 //Rate of falling peak dot
#define INPUT_FLOOR 10 //Lower range of analogRead input
#define INPUT_CEILING 300 //Max range of analogRead input, the lower the value the more sensitive (1023 = max)
byte peak = 16; // Peak level of column; used for falling dots
unsigned int sample;
byte dotCount = 0; //Frame counter for peak dot
byte dotHangCount = 0; //Frame counter for holding peak dot
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_PIXELS, LED_PIN, NEO_GRB + NEO_KHZ800);
void setup()
// This is only needed on 5V Arduinos (Uno, Leonardo, etc.).
// Connect 3.3V to mic AND TO AREF ON ARDUINO and enable this
// line. Audio samples are ‘cleaner’ at 3.3V.
// COMMENT OUT THIS LINE FOR 3.3V ARDUINOS (FLORA, ETC.):
// analogReference(EXTERNAL);
// Serial.begin(9600);
strip.begin();
strip.show(); // Initialize all pixels to ‘off’
void loop()
unsigned long startMillis= millis(); // Start of sample window
float peakToPeak = 0; // peak-to-peak level
unsigned int signalMax = 0;
unsigned int signalMin = 1023;
unsigned int c, y;
// collect data for length of sample window (in mS)
while (millis() - startMillis < SAMPLE_WINDOW)
sample = analogRead(MIC_PIN);
if (sample < 1024) // toss out spurious readings
if (sample > signalMax)
signalMax = sample; // save just the max levels
else if (sample < signalMin)
signalMin = sample; // save just the min levels
peakToPeak = signalMax - signalMin; // max - min = peak-peak amplitude
// Serial.println(peakToPeak);
//Fill the strip with rainbow gradient
for (int i=0;i<=strip.numPixels()-1;i++){
strip.setPixelColor(i,Wheel(map(i,0,strip.numPixels()-1,30,150)));
//Scale the input logarithmically instead of linearly
c = fscale(INPUT_FLOOR, INPUT_CEILING, strip.numPixels(), 0, peakToPeak, 2);
if(c < peak) {
peak = c; // Keep dot on top
dotHangCount = 0; // make the dot hang before falling
if (c <= strip.numPixels()) { // Fill partial column with off pixels
drawLine(strip.numPixels(), strip.numPixels()-c, strip.Color(0, 0, 0));
// Set the peak dot to match the rainbow gradient
y = strip.numPixels() - peak;
strip.setPixelColor(y-1,Wheel(map(y,0,strip.numPixels()-1,30,150)));
strip.show();
// Frame based peak dot animation
if(dotHangCount > PEAK_HANG) { //Peak pause length
if(++dotCount >= PEAK_FALL) { //Fall rate
peak++;
dotCount = 0;
else {
dotHangCount++;
//Used to draw a line between two points of a given color
void drawLine(uint8_t from, uint8_t to, uint32_t c) {
uint8_t fromTemp;
if (from > to) {
fromTemp = from;
from = to;
to = fromTemp;
for(int i=from; i<=to; i++){
strip.setPixelColor(i, c);
float fscale( float originalMin, float originalMax, float newBegin, float
newEnd, float inputValue, float curve){
float OriginalRange = 0;
float NewRange = 0;
float zeroRefCurVal = 0;
float normalizedCurVal = 0;
float rangedValue = 0;
boolean invFlag = 0;
// condition curve parameter
// limit range
if (curve > 10) curve = 10;
if (curve < -10) curve = -10;
curve = (curve * -.1) ; // - invert and scale - this seems more intuitive - postive numbers give more weight to high end on output
curve = pow(10, curve); // convert linear scale into lograthimic exponent for other pow function
Serial.println(curve * 100, DEC); // multply by 100 to preserve resolution
Serial.println();
// Check for out of range inputValues
if (inputValue < originalMin) {
inputValue = originalMin;
if (inputValue > originalMax) {
inputValue = originalMax;
// Zero Refference the values
OriginalRange = originalMax - originalMin;
if (newEnd > newBegin){
NewRange = newEnd - newBegin;
else
NewRange = newBegin - newEnd;
invFlag = 1;
zeroRefCurVal = inputValue - originalMin;
normalizedCurVal = zeroRefCurVal / OriginalRange; // normalize to 0 - 1 float
// Check for originalMin > originalMax - the math for all other cases i.e. negative numbers seems to work out fine
if (originalMin > originalMax ) {
return 0;
if (invFlag == 0){
rangedValue = (pow(normalizedCurVal, curve) * NewRange) + newBegin;
else // invert the ranges
rangedValue = newBegin - (pow(normalizedCurVal, curve) * NewRange);
return rangedValue;
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
@Cristian_Martinez Please use http://gist.github.com when sharing code. It makes it much easier to read and we can refer to line numbers that way.
Im on a phone right now with 1x data so im having to use copy and paste with the pages i already have open. But will do sir! Also can i use paste bin? Thats usually my go to for pasting code.
Pastebin is good too. It seems that G+ has flagged pastebin posts as spam a few times though so Daniel is currently recommending github.
Ah that explains why my first post on here wouldnt show up. I havent had any issues since thou.
http://pastebin.com/A3NKXED8
Ursula’s seashell code
http://pastebin.com/8LE4HzpF
changing the noise to 400 seemed to make the sensitivity bury itself underground, so its not as reactive now and doesnt look like a strobe light when you play it lol
