What extruders are you guys with i3s and e3d hot ends running.
What extruders are you guys with i3s and e3d hot ends running. In wanting to do direct drive with this. I would do a wades mount but would rather go direct with an mk8 or similar gear. Suggestions?
At this point im after a “Use this Link to extruder model you can print” haha. Just want to bolt something to this printer and use it tonight.
Im developing too many other projects I just need an extra printer that works
No one?
@Joe_Spanier sorry. I don’t have an I3. I have been learning Bowden. But the ezstruder from seemecnc works well. Just sandwich a mount between the nema and the ezdtruder. I have one laying around you could try. Otherwise the don’t cost much.
I’m actually running one on Bowden now Eric. I picked one up at Reprap fest after seeing yours. I wanted to do this guy direct and figured with the density of these someone would have an idea I could just print and throw on. But if nothing comes up ill just draw up an e3d collar to bolt to it and run Bowden.
Eventually I would like to use this one with ninjaflex. We are playing with it at work and its amazing. I want to do dual extrustion with it and abs for flexible couplers and things for z screws or possible eustanthios direct drive couplers.
I’ve also realized I printed the wrong parts for this thing. I used the models from the prusa-vanilla repo. Apparently most people are using the box-frame models. So if I change my x some of the adaptors and things I’ve printed already might work.
Not sure if it helps Joe but I love my mk5 direct drive extruder on my S3. I don’t. If there is a mounting option for your printer
It might be because I use 3 mm filament and like to extrude by hand to determine the nozzle temperature for a filament, but I like light-weight geared extruders using a Mk8 hobbed gear. This means I can use a smaller, lighter, stepper.
In case you are interested, the latest design I use on my Prusa i3 box frame is here (along with the design rationale):
Thanks kit I’ll take a look later today!
