What gcode command do I use to pause a print in +OctoPrint so that
What gcode command do I use to pause a print in +OctoPrint so that I can change the filament on my Printrbot Simple Metal? Cura’s pause at Z plugin (M0 I think) didn’t seem to work in the stable OctoPi build (paused, but then couldn’t unpause) but I haven’t tried it since I switched to the devel branch. Should I use @pause, filament change, M0, or something else? Thanks!
M0 and then just clicking the “Resume” button in the UI should work actually.
M0 works for us!
Ok, I’ll try this.
It works! Is " - event: Waiting" the correct config to get pushover notifications of this? Or paused?
http://docs.octoprint.org/en/master/events/index.html#printing :wink:
Waiting didn’t work. Then realized I forgot type: system. Will try again.
Yep! That fixed it. Thanks for all the help :slight_smile:
Thought it was M00
Cura is using M0 now, which works.
https://twitter.com/Klikini/status/550508127096147968
