What is the pin to pin length of the do gone on the Conrad
What is the pin to pin length of the do gone on the Conrad driveshafts? Conrad doesn’t ship to the US and I am trying to find something comparable. Any other driveshaft recommendations?
im trying some HSP shafts as they are MUCH cheaper, i only found one seller that has the sizes listed though http://www.ebay.com.au/itm/181037854345
i ordered the 188015 as it seems to be the closest length to the dog bones im using now
(these are the dog bones http://www.ebay.com.au/itm/380554906324 and the axles are the thunder tiger PD6018. but im sure there is a cheap HSP model that will fit)
just to let you know, the HSP CVD shaft part no 188015 does fit, BUT it has no holes in the shaft for the axle pins, instead it has a D shaft, but i think the holes could be drilled easily, but i think they are designed to use these http://www.ebay.com.au/itm/08065-Wheel-Hex-HSP-1-10-Scale-RC-Parts-8065-/290776924091
