What is the proper steps/mm to use when using the Golmart 1204 ball screw
What is the proper steps/mm to use when using the Golmart 1204 ball screw with 32t GT2 Pulleys?
I have to make a lot of assumptions to come up with a number
800
I have assumed the following
16x microstepping
200 steps per revolution motors
matching toothed pulleys since you only mention 1 size, one on the motor and one on the transmission shaft. meaning there is a 1:1 gear ratio
That is what I came up with with the RepRap steps calculator. They are 1204 Ball screws with 4mm pitch
It depends on your stepper setup. Is it 1/8, 1/16 or 1/32?
