I have been having problems with printing lately an i am really confused.
I have always had to have a negative g-code setup (about -0.4mm) in simplify3d to get the head close enough to the bed to get it to stick.
Now i thought i should check my z height and gamma value setting, but it is all really weird.
If i use the method to set gamma max as per the wiki: Finding gamma_max manually
First home the machine
G28
Then set the current Z position to 0
G92 Z0
Then move the head to the bed, using G0 Z(position) or Pronterface or the web interface.
Once the head is exactly at the bed, issue this command
M114
As soon i enter G0 Z0 (as i think that should be at the bed) it want to go UP not down (crashing into my endstops at top).
If i use the other method (manual method)
The the machine thinks z0 is about 2/3 down from top (gamma_max is set to 618.2) as it is my height from top to bed.
But M114 says it is at z0.
Where does it get 2/3 down from??
And if i then jog down to the bed and issue the M306 Z0 command which will use the current Z position as a homing offset.
Then save to the SD card with M500.
It still wants to stop at 400 next time i use the G0 Z0 command. It does not save the setting it seems.
If i G28 (at the top at endstops) and M114 it reports z 400.6791
