What server like programs do you use to run your printers? Right now I have repetier server on a Linux box and would like to stay with a Linux box if possible
OctoPrint is probably the most popular.
I’ll check it out
Have you ran any other programs?
5 Octoprint instances running 5 printers
Will octoprint do 2 printers in one instance?
@Abc_Def - not simultaneously.
So how would controlling two printers at once work? I have repetier server port forwarded to access outside of the house. Would I be able to do that with both printers in octopi?
@Abc_Def - You’d forward 2 ports from 2 instances. IE, one on 5000 and one on 5001
I use BotQueue to control multiple printers simultaneously but then again I’m biased
Repetier server is way underrated. I use it to control 3 printers. Too bad it doesn’t work with Sailfish firmware.
I’ve also been using octoprint on a pi 2b for a while. Very satisfied.
From what I’ve seen I believe repetier server will be the best
Cups?
