What type of connectors are you guys using to connect all the accessories around the extruder (e.g. Fans, probes,…)
I want to be able to easily swap extruders and add-ons.
Thanks
Thanks
I currently run molex locking but I really like the single ATX style connectors where you can have all your connections in one connector so you can easily swap out hotends/extruders
15pin DSUB is a cheap and easy to get connector. The heater cartridge uses 2+2 pin because the Ampere. 15pins is enought to have
If you want to have a Z-probe like BLTouch you will have to use common GND.
That reduces the pinusage for each function
If you dont like the idea of common GND then 25-pin DSUB is another solution
@Johnny_Linden I think most controller boards use low-side switching so common ground is not a good idea…
@TomvdZ I copied the RigidBot connector to 15-pin DSUB. I belived it was common GND
Molex microfit 3.0 for all. Up to 5amp and also compact
Some more love for the molex microfit.
@Stephanie_A @Step_Cia
That’s the stuff I was looking for. Thanks.
JST connectors come in 2, and 4 pin setup, do not require special crimpers and are as cheap as dirt on aliexpress
