Whats best to use when cleaning lens and mirrors, Accetone, or rubbing alchohol\???
Whats best to use when cleaning lens and mirrors, Accetone, or rubbing alchohol???
Thanks
I would say it’s depend on your mirrors, just to mention a very light gold coating could go quick if you rub to much. best is a good air assist. (I did post a photo of shatered stock mirror, for evidence)
I used mineral turpentine or methylated spirits on the end of a cotton earbud to clean mine (before adding air-assist). Seemed to clean reasonably easy with either of them.
I always try the gentlest cleaning agent first. So I just use simple rubbing alcohol on a Qtip. I don’t press hard - just keep lightly swabbing with a wet swab. Let the alcohol (or whatever solvent you use) do the work. As the wet swab comes away clean I do a final swipe with a dry one so I don’t get any film forming from evaporation.
Air assist definitely helps cut down how much dirt gets on the lens.
Rubbing alcohol usually has oil in it. If the oil remains on the optics in operation, there is a chance they will be damaged. If the acetone is pure, of the two it is the better choice in my opinion.
@Joel_Kunze ​ Interesting. The stuff I use is listed as 91% isopropyl alcohol and 9% water. I found a bottle of 70% in the bathroom that was labeled rubbing alcohol (the 70% is isopropyl alcohol). I’ve seen it with coloring & scents added - might that be where the oil comes in?
I’ve noticed just recently when cleaning my mirrors & lens that there was some sort of buildup on the mirrors in particular. It looked like when you get toothpaste splatter on the bathroom mirror. Cleaning with turps/metho that I was previously using didn’t seem to get rid of it, so I thought it may be burned into the mirror or whatever. I took it to the sink & washed with water (I don’t even know what made me consider that). Turns out, just washing with water & my finger got rid of all the marks & cleaned it very well. I did use my airpump to blow all the water off & dry the mirror as quick as possible (to prevent spots/streaks). Ever since I did that, I’ve been getting wonderful results cutting/engraving.
