I just recently got a K40 and decided that I needed a rotary axis for engraving shotglasses!
Now I have the mini2 stock board and am trying to get the rotary axis working properly but it is giving me headaches. The shotglass is directly mated to the stepper motor and spins at a 1:1 with the stepper. The shotglass averages about 37.5mm in diameter. What settings do I need to change in CorelLaser to get this dang thing to work right??
There might be a few people using the stock board with a rotary but I can’t recall anyone specifically off the top of my head. I know in the corellaser engrave window there is a rotary tool option, in the bottom right, you will probably need to check and it gives you other parameters to set. Out of curiosity, what are you using as a rotary?
@Nedman I am using a standard nema 17 stepper with a 3d printed cone pressed on to the shaft and a bearing in the rear to allow it to rotate smoothly. I haven’t seen any rotary chucks that are direct drive so I may be on my own with this one. I have fooled with the rotary setting but none of the extremes get me any closer.
Well, having never tried the rotary settings… It seems to me that if the “tire” that rotates the workpiece were a size (or geared down) so that it was the same steps/mm as the y axis it would work.
In other words if the tire was the same size as the sprocket that the belt rides on, the software wouldn’t need to know the difference.
