What’s the best kit for a large volume printer? Looking to build something that works great with flexible, Cooper pretty much all exotic filaments
What sort of axial dimensions are you looking for? Are you set on a kit or are you open to a prebuilt machine or building one from scratch and sourcing your own parts? You wont find many large volume printers as kits. That being said there are a few that do exist. With nearly any kit you get you can replace the hotend with an E3DV6 which will be able to fill your material requirements. If you want to be able to print with flexible filaments you should stay away from a bowden setup.
I have heard good things about this printer.
CreatorBot 3D DIY Kit
http://www.3dprinterworks.net/3dprinters.html
@Adam_Steinmark I’m fine with something near 30x30x30 cm. Needs to be a kit as I want all to be sourced for me.
