What’s your nozzle made of? If Other or suggestions add bellow
I like anti-stick coated brass. Good thermal behavior with less burnt-plastic fouling of the sides of the nozzle.
The brass nozzles I’ve used have worked fine. Want to get a stainless steel nozzle to print metal filaments.
standard e3d brass nozzle, all I print is petg / abs and it seems to work ok.
Unobtanium nozzles for me. When you’re using several million atmospheres of pressure to extrude synthetic diamond nano-powders to print gravitational lenses matrixes for my di-lithium warp drive. Only the best will do
@Kura_kuea better off with hardened steel. More wear resistant than stainless.
