Where to find bronze bushings?
I kinda fell out of circulation there for a year or so, but I’m now in a position to continue my build. Divorce will do that to a person.
Anyhow, so I’ve noticed that it appears Ultibots is no longer around, and I’ve not been to successful sourcing the 10 mm sintered bronze bushings. Anyone know where I might find some?
Thanks in advance
McMaster, maybe?
amazon?
https://amzn.to/3frDf3U
Panel-Mount Oil-Embedded Sleeve Bearing, for 8 mm Shaft Diameter, 11.5 mm Long
Or
Oil-Embedded Sleeve Bearings, for 10 mm Shaft Diameter, 11.5 mm Long
Or
https://shop.sdp-si.com/catalog?cid=p469
I used the ones from Stock drive parts recently, got them quickly and they fit perfectly.
Thank you all. This really helps!
Okay, wasn’t paying close enough attention. I’m gonna guess these are the ones😬
Yes. Also these ones work:
They arrive Thursday.
I think I’m finally in a position to start assembly on this thing! 2-1/2 years later, I think?
