Where’s a good resource/forum/etc. for Rumba controllers? Mine is working…partially…and I can see it in the Arduino Serial monitor, but I cannot send a modified Marlin update to tell it it’s a Delta printer and not a cartesian one…
A Rumba controller is just a custom-boarded Arduino Mega 2560. Any knowledge that applies to an Arduino Mega applies to the Rumba.
I’m getting: “avrdude: stk500v2_ReceiveMessage(): timeout”
When attempting to push and updated firmware to the board. Communication is partially working, as I can in the Serial port monitor, the servo cycle that the board does by default when it’s not actively trying to print something.
I had that issue at points when programming a friends Rumba as well; I had to unplug, replug, and flash the firmware right after. Once I got it to stop doing that stupid script, it was fine.
I had similar issues with a RAMBo board recently. Disconnect USB, Power cycle, reconnect and flash right away fixed it for me.
Thanks guys, it’s happy now, well, happier. Now it complains because it’s not functionally complete (thermistors not installed), so I can’t watch the servos print a phantom object…
@Mike_Miller , if you want it to print a phantom object, disable min-temp, and put a file called auto0.g in the root of the SD reader with your gcode for a print.
Mavericks osx messes up the serial driver so u get that error u can revert to the old driver
I’m getting pretty good at hitting ‘compile, power on, plug in the Rumba’
@Glenn_West First I’ve heard of that problem with Mavericks. That’s what I’m running. I’ll have to keep an eye on it.
Yep drive me crazy
Man, there’s GOT to be a better way. I can get this thing to upload firmware about 1 time in 15, with a ‘unplug RUMBA, power off, press compile, count to 2, turn on RUMBA count to 1-3, plug in RUMBA’
What are u programming it on. When I first flashes my rumba I had a bad USB cable and it caused me grief
I’ll swap cables and retest…it’s a Mac, running Arduino 1.0.5
Maverick ?
yeah. (following your instructions listed here: http://3dwest.blogspot.sg/2013/12/arduino-in-osx-109-stk500recv.html?m=1 ) I’ll let you know if it changes anything.
Holy crap, thanks! I’m 1 for 1!
Great.
Meh…that wasn’t it. It may have been the reboot that did it, I’m back to a really crummy success rate.
