Which License is better to make things open ?
There are lots of license like CC, GPL, etc. recently came across this http://www.ohwr.org/licenses
I am planning to post my designs under open license. Not sure which one to choose.
Also learned that a thing cannot be patented or can be nullified if it was
“In order to qualify for registration, patents must be novel and non-obvious. Novelty means the invention being patented must not have been publicly written about, patented, or invented before the patent was filed. Those types of publications are known as prior art.”
So planning to post them in a blog, with proper license.
Depends also on where you will share your works, Thingiverse, for example, has a list you can choose from (wide selection) but you are limited to that list.
Inventions (solutions to a problem) can be patented, so if your thing is part of the solution then it can be patented, but that is not consistent with open licencing, unless you maybe do a open-non-commercial licence, but you would have to secure the patent before releasing anything to the public.
