While in laserdraw I can’t seem to stop it from repeating. The setting for repeating is constantly at 1. I tried to lower it to 0 but it reverts back to 1. Anyone have a way to stop it from doing that? Thank you.
just to add clarity- this is while I am in the ‘cutting’ mode
@Jeremy_Hill Make sure your line widths are less than 0.001 in or mm. The thinner the better.
will that help to stop it from repeating or just minimize the issue? I will give it a try on my next cut.
Should stop it altogether.
Also make sure you have no double lines.
Ok. Thanks!
It should always be on repeat 1, as that means it will do 1 cut. Lower is not possible as it would do 0 cuts. The wording is incorrect for the option. It should really be called “Passes” rather than “Repeat”.
Thanks again. I appreciate the help
