While some 3D printers have gotten bigger, others have gotten smaller. Check out this 3-D Printer that folds to barely over an inch thick. http://tiny.cc/4n673w
It gets much bigger once you strap on the DLP projector that it requires to operate.
Will it work with a pico projector?
@Scojet_Inc Try not to use URL shorteners.
@Mark_Durbin probably not, since picos are usually based on LEDs, which emit practically no UV light at all.
I wonder if it could use the same “projector” that the Peach machine uses, seems like that could be made pretty small…
