Who here is running a Smoothie with a rotary 4th-axis?
Who here is running a Smoothie with a rotary 4th-axis? How did you compile the firmware? The command I used was
make AXIS=4 PAXIS=4 CNC=1
but after reading I’m not sure that was correct if I wanted the 4th axis to be rotary.
Don’t touch paxis
Ok, so just AXIS=4 should do me. Got it.
Axis and CNC
oh yeah…forgot that…:slight_smile:
OH, also.. It says to add some stuff to the config like the line below. Is it safe to assume that “delta_steps_per_mm” is actually steps per degree as suggested?
A axis
delta_steps_per_mm 100 # may be steps per degree for example
