Who out there is using the smoothieboard on the HercuLien? I worked with @Dennis_P and have made several solid steps forward, but somewhere I am still missing something with the Z height. I looked back in the discussion history for the proper calculations, and tried twice with the Triffid Hunter Calibration Guide, and tried the setting for gamma with the results, but I still cannot get it right, so I am asking what your setting is for gamma:
alpha_steps_per_mm 80 # Steps per mm for alpha ( X ) stepper
beta_steps_per_mm 80 # Steps per mm for beta ( Y ) stepper
gamma_steps_per_mm 3200 # Steps per mm for gamma ( Z ) stepper
This is my last setting, but it is wrong. I doubled the 1600 because initially it seemed to be half the proper height. I may have calculated it wrong too. Each time I calculated I tried a print, but all have not gotten me to 50mm on the test cube for the height.
I do have the standard BOM parts, 12 mm lead screws (2mm pitch), with 36 tooth on them, and the 20 tooth on the stepper motor. Standard motor with 1.8 degree step as well.
