Rob. TinyG has a low PWM output. i.e. it outputs a pulsed square wave proportional to the speed value you desire. The drive you need must therefore be able to accept that ppm signal and output a voltage (or frequency) sufficient to control the speed of your spindle.
If your spindle is a DC Spindle you need to vary the DC voltage to regulate the speed. If your spindle is a 3 phase AC spindle then you’ll need to vary the AC frequency in the spindle which is where a VFD or Variable frequency drive comes in.
The link you shared generates a PWM signal output as you turn the knob. This could be useful as a dimmer for LEDs or even as an efficient means to vary the speed of a DC spindle. Which could be useful as a stand alone form of speed control. It will not however allow you to remote control the speed of your spindle via the TinyG and G-Code commands.
…one more thing the output voltage of the speed control module should not exceed the rated DC voltage of the spindle. It should also be able to supply enough current (amps) maximum load.
