With replicape connected to Ethernet,
With replicape connected to Ethernet, I was able to access octoprint wirelessly on my laptop by going to kamikaze.local:5000 on chrome. But I could not get the same result if I try on tablet or phone… Strange… It shouldn’t matter what device I’m on as long as it’s on the same network right?
The .Local suffix is from the bonjour protocol, if your phone doesn’t use it it won’t work. But your router might have a DNS and give you a host name locally instead. Use that and no need for the :5000 port number
When I tried without :5000 on my laptop it actually just gives me a Google search…
Try putting http:// in front. Which version of kamikaze are you running?
Thanks local host works also with http infront works as well :slight_smile:
