Working on my laser mount so I can use my laser interchangeably with my spindle.
https://youtu.be/L2Iv-HuetwI
John, if you don’t mind…what laser are you using and are you able to cut with it or engrave only?
I made this so I can swap out lasers fairly easily. I use a super high power NUBM44 running at 6W for cutting mylar or burning off PCB pads of solder mask. I use a lower power UV laser BDR209 for 0.1mm precise UV exposing or burning. Both are available at https://sites.google.com/site/dtrlpf/
